Wiki.js - Your Personal Knowledge Base [Part 8 of 10]
Organize documentation, notes, and knowledge in a beautiful wiki
Need a place to document everything? Store notes? Create guides? Build a knowledge base?
Wiki.js is a modern, powerful wiki platform that makes documentation beautiful and easy.
Features:
  • Beautiful, modern interface
  • Markdown editor with live preview
  • Rich text editor option
  • Full-text search
  • Version history for all pages
  • User permissions and groups
  • Multiple authentication methods
  • Asset management (images, files)
  • Export to PDF, HTML, Markdown
  • Dark mode support
Let’s set it up!
What is Wiki.js?
Wiki.js is a modern wiki software built on Node.js.
Perfect for:
  • Personal documentation - How-to guides, notes, references
  • Project documentation - Technical specs, API docs
  • Team knowledge base - Shared information, procedures
  • Learning notes - Study materials, tutorials
  • Recipe collection - Yes, people use it for recipes!
Why Wiki.js?
  • Clean, modern interface
  • Fast and lightweight
  • Easy to use (no complex syntax)
  • Powerful search
  • Version control built-in
  • Free and open source
What You’ll Need
Prerequisites
  • Docker and Portainer running (Part 4)
  • Nginx Proxy Manager configured (Part 5)
  • At least 2GB RAM
  • Storage space for wiki content
Ports Required
  • Port 3000 - Wiki.js web interface
Installing Wiki.js
Wiki.js uses two containers:
  • wikijs - Main application
  • PostgreSQL - Database for content storage
We’ll deploy them as a stack in Portainer.
Step 1: Create Data Directory
On your Ubuntu server (via SSH):
# Create directory for Wiki.js database
sudo mkdir -p /mnt/storage/docker/wikijs/postgres
# Set ownership (replace 'admin' with your username)
sudo chown -R admin:admin /mnt/storage/docker/wikijs
Step 2: Generate Database Password
Generate a secure password for PostgreSQL:
# Generate a 32-character password (A-Z, a-z, 0-9 only)
openssl rand -base64 32 | tr -dc 'A-Za-z0-9' | head -c 32
Save this password - you’ll need it in the next step!
Step 3: Deploy via Portainer
Login to Portainer:
https://portainer.homelab.example.com
Create new stack:
  1. Click Stacks in left sidebar
  2. Click + Add stack
  3. Name: wikijs
  4. Build method: Web editor
Paste this compose configuration:
version: '3.8'
services:
wikijs:
container_name: wikijs
image: ghcr.io/requarks/wiki:2
environment:
DB_TYPE: postgres
DB_HOST: wikijs_postgres
DB_PORT: 5432
DB_USER: wikijs
DB_PASS: ${DB_PASSWORD}
DB_NAME: wikijs
TZ: America/New_York # Change to your timezone
ports:
- '3000:3000'
depends_on:
- database
restart: unless-stopped
networks:
- default
- portainer-network
database:
container_name: wikijs_postgres
image: postgres:17-alpine
environment:
POSTGRES_DB: wikijs
POSTGRES_USER: wikijs
POSTGRES_PASSWORD: ${DB_PASSWORD}
volumes:
- /mnt/storage/docker/wikijs/postgres:/var/lib/postgresql/data
networks:
- default
networks:
portainer-network:
external: true
Note about timezone:
  • Find your timezone: TZ Database Timezones
  • Examples: America/New_York, America/Los_Angeles, Europe/London, Asia/Tokyo
Step 4: Set Environment Variable
Scroll down to “Environment variables” section:
  1. Click + Add environment variable
  2. Name: DB_PASSWORD
  3. Value: Paste the password you generated in Step 2
  4. Click Add
Step 5: Deploy the Stack
Deploy:
  • Scroll down
  • Click Deploy the stack
  • Wait 2-3 minutes for deployment
Verify deployment:
  • Go to Containers in Portainer
  • Confirm both containers are running:
  • wikijs
  • wikijs_postgres
Step 6: Configure Firewall
# Allow Wiki.js from LAN
sudo ufw allow from 192.168.1.0/24 to any port 3000 proto tcp comment 'Wiki.js from LAN'
# Check firewall status
Note: Replace 192.168.1.0/24 with your network range.
Setting Up Proxy with NPM
Now let’s add Wiki.js to Nginx Proxy Manager.
Step 1: Create SSL Certificate
Login to NPM:
https://npm.homelab.example.com
Create certificate:
  1. Go to SSL Certificates
  2. Click Add SSL CertificateLet’s Encrypt
  3. Domain Names: wiki.homelab.example.com
  4. Use a DNS Challenge: Enable (if using DNS challenge)
  5. Email Address: Your email for Let’s Encrypt notifications
  6. Agree to Terms: Check
  7. Click Save
  8. Wait for certificate issuance (1-2 minutes)
Step 2: Create Proxy Host
In NPM:
  1. Go to HostsProxy Hosts
  2. Click Add Proxy Host
Details Tab:
  • Domain Names: wiki.homelab.example.com
  • Scheme: http
  • Forward Hostname/IP: wikijs (container name)
  • Forward Port: 3000
  • Cache Assets: Enable
  • Block Common Exploits: Enable
  • Websockets Support: Enable
SSL Tab:
  • SSL Certificate: Select your certificate
  • Force SSL: Enable
  • HTTP/2 Support: Enable
  • HSTS Enabled: Leave unchecked
Click: Save
Step 3: Test Access
Open your browser:
https://wiki.homelab.example.com
You should see the Wiki.js setup wizard!
First-Time Setup
Complete Setup Wizard
Step 1: Administrator Account
  • Email: Your email address
  • Password: Choose a strong password
  • Confirm Password: Re-enter password
  • Click Install
Need a strong password?
Step 2: General Settings
  • Site URL: https://wiki.homelab.example.com
  • Site Title: Choose a title (e.g., “My HomeLab Wiki”)
  • Click Continue
Step 3: Telemetry
  • Choose whether to send anonymous usage data
  • Click Continue
Step 4: Finish
  • Setup is complete!
  • Click Start to access your wiki
Using Wiki.js
Creating Your First Page
  1. Click: + New Page (top right)
  2. Select editor:
  • Markdown - Simple text formatting (recommended)
  • Visual Editor - Rich text WYSIWYG
  • Code - Raw HTML
  1. Choose path: /home or custom path
  2. Write content
  3. Click: Create (top right)
Markdown Basics
Wiki.js uses Markdown for formatting:
# Heading 1
## Heading 2
### Heading 3
**Bold text**
*Italic text*
- Bullet point
- Another point
1. Numbered list
2. Second item
[Link text](https://example.com)
![Image](image.jpg)
`inline code`
code block
Live preview shows your formatting as you type!
Organizing Pages
Use paths to organize:
  • /home - Home page
  • /guides/docker - Docker guide
  • /guides/networking - Networking guide
  • /recipes/pizza - Pizza recipe (why not?)
Paths create hierarchy:
  • Parent pages automatically list child pages
  • Breadcrumbs show links path
  • Search indexes all pages
Adding Images
  1. Click: Insert → Image
  2. Upload image or paste URL
  3. Add alt text (optional)
  4. Click: Insert
Images are stored in the database - no separate file management needed!
Page History
Every edit is saved:
  1. Click: Page Actions (⋮) → History
  2. View all versions with timestamps
  3. Compare versions side-by-side
  4. Restore any previous version
Never lose content again!
Search
Full-text search built-in:
  • Search box in top links
  • Searches all page content
  • Instant results
  • Highlights matches
User Management
Adding Users
As admin:
  1. Click: Administration (profile menu)
  2. Go to: Users
  3. Click: + New User
  4. Fill in:
  • Email
  • Name
  • Password (or send invite)
  • Group (permissions)
  1. Click: Create
Groups and Permissions
Default groups:
  • Administrators - Full access
  • Guests - Read-only access
Create custom groups:
  1. Go to: Administration → Groups
  2. Click: + New Group
  3. Set permissions:
  • Read pages
  • Write pages
  • Manage pages
  • Upload assets
  • Admin access
  1. Assign users to group
Customization
Change Theme
  1. Go to: Administration → Theme
  2. Choose:
  • Light mode
  • Dark mode
  • Auto (follows system)
  1. Customize colors (optional)
  2. Click: Apply
Add Logo
  1. Go to: Administration → General
  2. Upload logo image
  3. Set logo URL (optional)
  4. Click: Apply
Configure Footer
  2. Edit footer content
  3. Add links (privacy policy, contact, etc.)
  4. Click: Apply
Maintenance
Check Storage Usage
# Check Wiki.js database size
du -sh /mnt/storage/docker/wikijs/postgres
Backup Wiki
Backup database:
# Backup PostgreSQL database
docker exec wikijs_postgres pg_dump -U wikijs wikijs > wikijs-backup-$(date +%Y%m%d).sql
# Compress backup
gzip wikijs-backup-$(date +%Y%m%d).sql
Store backups off-site for redundancy!
Restore from Backup
# Decompress backup
gunzip wikijs-backup-YYYYMMDD.sql.gz
# Restore database
cat wikijs-backup-YYYYMMDD.sql | docker exec -i wikijs_postgres psql -U wikijs -d wikijs
Update Wiki.js
Via Portainer:
  1. Go to Stackswikijs
  2. Click Editor
  3. Click Update the stack
  4. Select Re-pull image and redeploy
  5. Wait for update to complete
Check for updates quarterly - Wiki.js is stable and updates less frequently than other services.
Use Cases
Personal Documentation
Document your HomeLab:
  • Server configurations
  • Network diagrams
  • Troubleshooting guides
  • Command references
  • Service documentation
Project Notes
Track projects:
  • Project goals and requirements
  • Design decisions
  • Implementation notes
  • Testing procedures
  • Lessons learned
Learning Notes
Study materials:
  • Course notes
  • Tutorial summaries
  • Code examples
  • Reference materials
  • Practice exercises
Recipe Collection
Yes, really:
  • Organize recipes by category
  • Add photos
  • Track modifications
  • Share with family
  • Search by ingredient
  • Wiki.js is a modern wiki platform
  • Features: Markdown editor, version history, search, permissions
  • Installation: Deploy two-container stack via Portainer
  • Setup: Simple wizard, no email required
  • Organization: Use paths to create hierarchy
  • Backup: Export database regularly
  • Next: We’ll set up OpenSpeedTest for network monitoring in Part 9
What will you document in your wiki?
Do you currently use any note-taking apps?
Excited about having your own knowledge base?
Links: ← Part 7 | Part 9 →
