Why You Should Ditch the Microsoft Account and Stop Using Admin [Standalone Guide]
Two simple changes that make Windows 11 way harder to break
Microsoft really wants you to sign in with a Microsoft account when you set up Windows 11. They make it hard to skip. They hide the local account option. They guilt you with warnings about “missing features.”
And once you’re signed in? You’re an administrator by default. Full control. No safety net.
This is backwards. Linux and macOS got this right years ago. You don’t run as root. You don’t have god-mode access for everyday tasks. You authenticate when you need admin privileges, and the rest of the time you’re protected from yourself.
Windows can work the same way. It just takes two changes.
Why Microsoft Sets You Up Wrong
The Microsoft Account Push
Microsoft wants you logged into their cloud because:
  • Telemetry - They can tie your activity to an identity
  • OneDrive - Your files sync to their servers by default
  • Microsoft 365 - Easier upsell when you’re already signed in
  • Account recovery - Sounds helpful, but it means they control access to your machine
  • Advertising ID - Personalized ads across devices
A local account breaks this chain. Your login is just a username and password on your machine. No cloud sync. No identity tracking. No “sign in to continue” prompts.
The Admin Problem
When you set up Windows, your account is an administrator. This means:
  • Any program you run has full system access
  • Malware doesn’t need to “boost” if you’re already admin
  • A bad link in an email can install software without extra prompts
  • Ransomware runs with your permissions and encrypts everything you can access
Think about it. You click a link. It downloads something. You double-click it because you’re curious or it looked legitimate. It runs. And because you’re an admin, it can do whatever it wants.
On Linux, that same action would fail. The installer would ask for your password. You’d have a moment to think. That friction saves people every day.
Windows has this too. It’s called UAC (User Account Control). But when you’re an admin, UAC just asks “Do you want to allow this?” and most people click Yes without reading.
When you’re a standard user, UAC asks for an admin password. That’s a real barrier. That’s the friction that makes you stop and think.
The Fix: Two Accounts
Here’s the setup that actually makes sense:
  1. Admin account - Used only for installing software and making system changes. You log into this rarely.
  2. Standard user account - Your daily driver. Email, browsing, documents, everything. No admin rights.
When you need to install something, Windows prompts for the admin password. You type it, the install happens, and you go back to being a standard user. Just like sudo on Linux.
Step 1: Create a Separate Admin Account
Before you demote your main account, you need another admin account to fall back on.
Open Settings
  1. Press Win + I to open Settings
  2. Go to Accounts > Other users
  3. Click Add account
Create a Local Account (Not Microsoft)
  1. Click I don’t have this person’s sign-in information
  2. Click Add a user without a Microsoft account
  3. Enter a username
Naming tips:
  • Don’t use “Admin” or “Administrator” (too obvious, easy target)
  • Pick something you’ll remember but isn’t guessable
  • Examples: Your initials + a number, a nickname, a reference only you’d get
  • Avoid your name, pet names, birthdays, or anything on your social media
  1. Create a strong password (use your password manager)
  2. Fill in the security questions (required, unfortunately)
  3. Click Next
Make It an Administrator
  1. Back in Other users, click on the new account
  2. Click Change account type
  3. Select Administrator
  4. Click OK
Step 2: Convert Your Microsoft Account to Local
If you’re currently using a Microsoft account, convert it to local before demoting.
Sign Out of Microsoft Account
  2. Go to Accounts > Your info
  3. Click Sign in with a local account instead
  4. Enter your current Microsoft account password
  5. Create a local username and password
  6. Click Next, then Sign out and finish
You’ll be logged out. Log back in with your new local credentials.
What you lose:
  • OneDrive sync (you can still use OneDrive, just sign in separately)
  • Settings sync across devices
  • Microsoft Store purchases tied to your account (you can sign into the Store app separately)
What you keep:
  • All your files
  • All your installed programs
  • Your desktop, documents, everything
Step 3: Demote Your Daily Account to Standard User
Now for the important part. Log out of your daily account and log into the admin account you created.
Log In as Admin
  1. Click Start > your profile icon > Sign out
  2. On the login screen, select the admin account
  3. Enter the password
Demote Your Main Account
  3. Find your main account (the one you normally use)
  4. Click on it, then Change account type
  5. Change from Administrator to Standard User
  6. Click OK
Log Back Into Your Main Account
  1. Sign out of the admin account
  2. Log into your regular account
You’re now running as a standard user. Your admin account is there when you need it.
What Changes Day-to-Day
Installing Software
Before: Double-click installer, click Yes on UAC, done.
Now: Double-click installer, enter admin password, done.
That’s it. One extra step. But that step makes you think about what you’re installing.
System Settings
Some settings require admin rights:
  • Adding/removing programs
  • Changing network settings
  • Windows Update (can still run automatically)
  • Installing drivers
When you try to change these, you’ll enter the admin password. Everything else works normally.
What Doesn’t Change
  • Browsing the web
  • Email
  • Office documents
  • Most applications
  • Playing games (already installed)
  • Watching videos
  • File management
90% of what you do doesn’t need admin rights. You won’t notice the difference most of the time.
Real-World Attacks This Stops
Drive-by Downloads
You visit a compromised website. It tries to download and run malware. As a standard user, the malware can’t install system-wide. It’s contained to your user profile at worst, and usually fails entirely.
Malicious Email Links
You click a link in a phishing email. It downloads a fake “invoice.exe”. You accidentally run it. As a standard user, it asks for admin credentials. You don’t have them handy (because you’re not the admin). You stop and think. You don’t get infected.
Bundled Installers
You download a free program. The installer tries to add toolbars, change your homepage, install “bonus” software. As a standard user, all those system changes fail. The core program might install, but the garbage can’t spread.
Ransomware
Ransomware encrypts your files. As an admin, it can encrypt everything, including system files and backups. As a standard user, it can only touch files you own. Still bad, but recoverable. And many ransomware variants fail entirely without admin rights.
Fresh Install Tip: Skip the Microsoft Account
If you’re setting up a new Windows 11 machine, you can skip the Microsoft account entirely during setup.
The Network Trick
When Windows asks you to connect to a network during setup:
  1. Press Shift + F10 to open Command Prompt
  2. Type: oobe\bypassnro
  3. Press Enter
The machine restarts. When you get back to the network screen, there’s now an option: I don’t have internet. Click it, then Continue with limited setup.
You’ll create a local account from the start. No Microsoft account needed.
Note: Microsoft keeps trying to close these workarounds. If this doesn’t work on your version of Windows 11, they may have patched it out in a recent update. Search for current methods if this fails, or just set up with Microsoft and convert to local afterward using the steps above.
  • Microsoft accounts tie you to their cloud and tracking
  • Local accounts keep your login on your machine only
  • Admin by default means any program you run has full control
  • Standard user means you enter a password for system changes
  • Create a separate admin account, then demote your daily account
  • This is how Linux and macOS work, and it’s safer
Are you running as admin right now? (Check Settings > Accounts > Your info)
Have you ever clicked something and immediately regretted it?
Does the extra password prompt seem worth it for the protection?
Drop a comment below.
