Building redundant storage so one drive failure doesn’t ruin your day
You’ve got your server running Ubuntu. Now let’s talk about storage.
If you’re running a HomeLab, you’re storing important data: photos, documents, configurations, databases. Losing that data because a single hard drive failed would be devastating.
Enter RAID 5 - a way to combine multiple drives into one array with built-in redundancy.
What is RAID 5?
RAID = Redundant Array of Independent Disks
RAID 5 combines 3 or more drives into a single storage pool where:
- Data is striped across all drives (fast performance)
- Parity information is distributed across drives (redundancy)
- One drive can fail without losing any data
- You get (N-1) × drive size of usable space
Example with 3 × 2TB drives:
- Total raw capacity: 6TB
- Usable capacity: ~4TB (one drive’s worth is used for parity)
- Can survive: 1 drive failure
Why RAID 5 for HomeLab?
Pros
- Data protection - One drive can fail without data loss
- Good performance - Reads are fast due to striping
- Efficient - Only “wastes” one drive’s capacity for redundancy
- Cost-effective - Better than mirroring (RAID 1) for capacity
Cons
- Slower writes - Parity calculations add overhead
- Rebuild stress - Rebuilding after failure stresses remaining drives
- Not a backup - RAID protects against drive failure, NOT accidental deletion, corruption, or disasters
Best For
- Docker container data
- Media libraries
- File storage
- Database storage
- Anything you can’t afford to lose
RAID is NOT a Backup
Important: RAID protects against hardware failure, not:
- Accidental file deletion
- Ransomware/malware
- Fire, flood, theft
- Filesystem corruption
- User error
You still need backups. RAID is one layer of protection, not the only one.
What You’ll Need
Choosing Your Drives
You have three main options, each with different trade-offs:
Option 1: NVMe SSDs (What I Use)
- Speed: Fastest (3000+ MB/s)
- Cost: Most expensive ($$$$)
- Capacity: Typically 1-2TB per drive
- Best for: Maximum performance, VMs, databases
- Requirements: M.2 slots on motherboard
- Example: 3× 2TB NVMe = ~4TB usable for $300-600
Option 2: SATA SSDs (Best Value for Speed)
- Speed: Fast (500-550 MB/s)
- Cost: Moderate ($$$)
- Capacity: 2-4TB per drive
- Best for: Great balance of speed and capacity
- Requirements: SATA ports on motherboard, 2.5" drive bays
- Example: 3× 4TB SATA SSD = ~8TB usable for $400-700
Option 3: 3.5" HDDs (Maximum Capacity)
- Speed: Slower (150-200 MB/s)
- Cost: Cheapest ($$)
- Capacity: 4TB+ per drive (up to 20TB+)
- Best for: Media storage, backups, large file archives
- Requirements: SATA ports on motherboard, 3.5" drive bays in case
- Example: 3× 8TB HDD = ~16TB usable for $300-450
My recommendation: For most HomeLab tasks (Docker containers, file storage, media), all three options work great. Choose based on your budget and capacity needs.
Important Considerations
Before buying drives, verify:
- Motherboard has enough connections
- NVMe: Check how many M.2 slots
- SATA: Check how many SATA ports (usually 4-8)
- Case has drive bays
- 2.5" bays for SATA SSDs
- 3.5" bays for HDDs
- M.2 slots don’t need bays
- Power supply has enough connectors AND wattage
- SATA drives need SATA power cables
- NVMe draws power from motherboard
- HDDs use more power: Each 3.5" HDD draws ~10W (idle) to 20W (active)
- Example: 4× HDDs = 40-80W additional power draw
- If using multiple large HDDs, consider a higher wattage PSU (650W+ recommended)
Drive compatibility:
- Same size drives recommended (e.g., all 4TB)
- Can mix brands (I’m using WD + Samsung)
- Can’t mix types (don’t mix HDD + SSD in same array)
Hardware Summary
- 3 or more drives (same size recommended)
- Available connections on motherboard
- Drive bays in case (if using SATA/HDD)
- Sufficient power from PSU
Software
- mdadm - Linux software RAID tool (free, built into Ubuntu)
- ext4 - Filesystem (reliable, well-supported)
My setup (as example):
- 3 × 2TB NVMe SSDs (2× WD_BLACK SN850X, 1× Samsung 980 PRO)
- ~3.6TB usable capacity
- Mounted at
/mnt/storage
RAID 5 Setup Process
Step 1: Install mdadm
# Update package lists
sudo apt update
# Install mdadm
sudo apt install mdadm -y
During installation, you’ll be asked about email notifications. You can configure this later.
Step 2: Identify Your Drives
Find your drives:
lsblk
You’ll see output like:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
nvme0n1 259:0 0 931.5G 0 disk
├─nvme0n1p1 259:1 0 512M 0 part /boot/efi
└─nvme0n1p2 259:2 0 931G 0 part /
nvme1n1 259:3 0 1.8T 0 disk
nvme2n1 259:4 0 1.8T 0 disk
nvme3n1 259:5 0 1.8T 0 disk
In this example:
nvme0n1= OS drive (don’t touch this!)nvme1n1,nvme2n1,nvme3n1= Empty drives for RAID
Your drives might be named:
sda,sdb,sdc(SATA drives)nvme0n1,nvme1n1,nvme2n1(NVMe drives)
** WARNING:** Make absolutely sure you’re using the correct drives. Creating a RAID array will erase all data on those drives.
Step 3: Create the RAID 5 Array
Create the array (adjust drive names to match yours):
# Create RAID 5 array with 3 drives
# Replace nvme1n1, nvme2n1, nvme3n1 with YOUR drive names
sudo mdadm --create /dev/md0 \
--level=5 \
--raid-devices=3 \
/dev/nvme1n1 /dev/nvme2n1 /dev/nvme3n1
You’ll be asked to confirm. Type y and press Enter.
The array will start building:
# Check progress
cat /proc/mdstat
You’ll see something like:
md0 : active raid5 nvme3n1[3] nvme2n1[1] nvme1n1[0]
3906764800 blocks super 1.2 level 5, 512k chunk, algorithm 2 [3/3] [UUU]
[>....................] resync = 2.3% (45678912/1953382400) finish=180.5min speed=176234K/sec
This can take hours depending on drive size. The array is usable during this time, but performance will be reduced.
Step 4: Create Filesystem
Once the array is created (you can do this while it’s still syncing):
# Create ext4 filesystem on the array
sudo mkfs.ext4 /dev/md0
This takes a few minutes.
Step 5: Create Mount Point and Mount Array
# Create mount point
sudo mkdir -p /mnt/storage
# Mount the array
sudo mount /dev/md0 /mnt/storage
# Verify it's mounted
df -h /mnt/storage
You should see:
Filesystem Size Used Avail Use% Mounted on
/dev/md0 3.6T 28K 3.4T 1% /mnt/storage
Step 6: Make it Permanent (Auto-mount on Boot)
Save RAID configuration:
# Scan for RAID arrays and save configuration
sudo mdadm --detail --scan | sudo tee -a /etc/mdadm/mdadm.conf
# Update initramfs (so array is available at boot)
sudo update-initramfs -u
Add to fstab for auto-mounting:
# Edit fstab
sudo nano /etc/fstab
Add this line at the end:
/dev/md0 /mnt/storage ext4 defaults 0 2
Save and exit: Ctrl+X, then Y, then Enter
Test the fstab entry:
# Unmount
sudo umount /mnt/storage
# Mount using fstab
sudo mount -a
# Verify
df -h /mnt/storage
If it mounts successfully, you’re good!
Step 7: Set Permissions
# Create docker directory
sudo mkdir -p /mnt/storage/docker
# Set ownership (replace 'admin' with your username)
sudo chown -R admin:admin /mnt/storage
# Verify
ls -la /mnt/storage
Verify Everything Works
Check Array Status
# Quick status
cat /proc/mdstat
# Detailed information
sudo mdadm --detail /dev/md0
Look for:
State : clean(array is healthy)[3/3] [UUU](all 3 drives are Up)
Check Filesystem
df -Th /mnt/storage
Should show:
Filesystem Type Size Used Avail Use% Mounted on
/dev/md0 ext4 3.6T 28K 3.4T 1% /mnt/storage
Monitoring and Maintenance
Check Array Health Regularly
# Quick check
cat /proc/mdstat
# Detailed status
Run Monthly Data Scrubs
A scrub checks for data corruption:
# Start a scrub
echo check | sudo tee /sys/block/md0/md/sync_action
# Monitor progress
watch cat /proc/mdstat
# Check for errors after completion
sudo mdadm --detail /dev/md0 | grep -i mismatch
If mismatches are found, the array will auto-correct them.
Recommended: Set up a monthly cron job to run scrubs automatically.
What Happens When a Drive Fails?
Detecting Failure
The array will automatically detect a failed drive:
cat /proc/mdstat
You’ll see:
md0 : active raid5 nvme3n1[3] nvme2n1[1] nvme1n1[0](F)
3906764800 blocks super 1.2 level 5, 512k chunk, algorithm 2 [3/2] [_UU]
Notice:
[3/2]- 2 out of 3 drives working[_UU]- First drive is down, others are Up(F)- Failed drive marker
Your data is still safe! RAID 5 can run with one failed drive.
Replacing a Failed Drive
1. Remove failed drive from array:
# Mark as failed (if not auto-detected)
sudo mdadm --manage /dev/md0 --fail /dev/nvme1n1
# Remove from array
sudo mdadm --manage /dev/md0 --remove /dev/nvme1n1
2. Physically replace the drive
- Shut down server
- Replace failed drive with new one
- Boot back up
3. Add new drive to array:
# Add new drive (adjust name if needed)
sudo mdadm --manage /dev/md0 --add /dev/nvme1n1
4. Monitor rebuild:
Rebuild will take hours. The array is usable during this time, but performance is reduced.
Performance Tips
Current Configuration
- Chunk size: 512 KB (good for large files)
- Filesystem: ext4 (reliable, well-supported)
- Read performance: Excellent (striped across drives)
- Write performance: Moderate (parity overhead)
tune for Your Workload
For large sequential files (media, backups):
- 512 KB chunk size is ideal (default)
For small random files (databases):
- Consider RAID 10 instead (better random I/O)
For maximum performance:
- Use SSDs instead of HDDs (what I’m using)
- NVMe > SATA SSD > HDD
- RAID 5 combines 3+ drives with redundancy
- Usable capacity: (N-1) × drive size
- Setup: Install mdadm, create array, format, mount, configure auto-mount
- Maintenance: Monitor health, run monthly scrubs
- RAID ≠ Backup - You still need separate backups
- Next: We’ll install Docker & Portainer in Part 4
What RAID level are you using (or planning to use)?
HDDs or SSDs for your array?
Ever had a drive fail and RAID save the day?
