Why your password habits are probably terrible (and what to do about it)
We talk a lot about cybersecurity, zero-days, and shadow IT, but none of it matters if someone just brute-forces your Netflix password because it’s Password123!. The truth? Most breaches start with a human, not a hacker.
This guide is about password hygiene, plain and simple. No scare tactics. Just straight talk and best practices that’ll actually keep you safer.
** Why Passwords Still Matter**
Even with passkeys, biometrics, and MFA, passwords aren’t going anywhere. Most systems still rely on them as a first line of defense.
Weak passwords are a goldmine for:
- Credential stuffing attacks
- Database dumps from old breaches
- Lazy internal actors
If you reuse passwords or make them easy to guess, you’re basically handing over the keys.
** Real Talk: What Not to Do**
These are still being used in 2025:
- qwerty
- password1
- letmein
- Your kid’s birthday
- Your dog’s name + year
And yes, attackers do try all of those.
What Not to Do with Temporary Passwords
Temporary or “throwaway” passwords still matter, they often get reused, left unchanged, or linger longer than they should. Here’s how not to handle them:
- Don’t use simple words or names like
temp123,changeme, orwelcome2025 - Avoid reused defaults like
Password1!,admin1234, or your company name + year - Never share temp passwords over unsecured channels like plaintext email or chat
- Don’t forget to expire or change temp credentials after use
Do this instead: Use a password manager to generate a random, complex string, even for temp access, and always enforce a reset on first login.
** How to Create a Strong Password (If You Still Insist on Doing It Yourself)**
You should be using a password manager, but if you’re dead set on making your own, here’s how to do it right:
- Length over complexity: Aim for at least 14-16 characters. Every character added exponentially increases strength.
- Use upper & lowercase letters: Don’t make it all lowercase. Mix it up.
- Add numbers: Randomly placed numbers are better than predictable dates.
- Throw in symbols: Don’t just slap an exclamation point at the end, actually embed symbols throughout.
- Avoid dictionary words: Even with leetspeak (like “P@ssw0rd”), modern cracking tools eat these alive.
- Think passphrase: Use a sentence or nonsensical combo, something like Correct#Horse9Battery%Staple! or RedFish.BlueSky_99! works well.
** Common Missteps**
- Don’t base your password on your login or email.
- Avoid obvious substitutions (like 0 for o, or 3 for e).
- Don’t use sequential keys (asdfghjkl) or keyboard walks (1qaz2wsx).
** Use a Password Manager**
No one can remember 100+ secure passwords. And if you’re still using one master password for 12 services, you’re asking for pain.
Great managers:
They’ll generate random passwords, store them safely, and sync across devices.
** Consider a Hardware Security Key (Like YubiKey)**
If you want real protection against phishing and account takeovers, nothing beats a hardware security key.
Devices like YubiKey add a physical layer of verification, meaning even if someone has your password, they can’t get in without the key.
- Works with most major platforms (Google, GitHub, Microsoft, etc.)
- No codes to copy, just plug in or tap
- Immune to phishing attacks and SIM swaps
If you’re serious about locking things down, especially developer tools or admin accounts, get one.
** Change Your Bad Habits**
You don’t need to update every password weekly, but you do need to:
- Rotate credentials after breaches
- Use unique passwords for every account
- Enable MFA where possible
Check your email/passwords against public breaches:
** Final Thoughts**
Hackers aren’t always super-genius coders. Sometimes they’re just lucky enough to guess your dumbass password.
Strong passwords aren’t just a checkbox, they’re the lock on your digital life.
So stop making it easy.
If you want more real-world security guides like this (not just theory), hit up the IT & Systems section, or drop a comment and let me know what to cover next.
Want More Like This?
If you found this guide helpful and want more straight-talking security tips (without the corporate jargon), check out the rest of the posts in the IT & Systems category.
Got a specific security topic or question you’d like to see covered? Drop a comment. I read them all.
Stay safe out there.
