How to Actually Comment Code Without Wasting Everyone’s Time
commenting, development, best-practices, code-quality, documentation
Introduction
Writing code isn’t enough, someone (possibly you) will have to read, debug, or improve it later. And if your comments are vague, missing, or useless, that person’s going to hate you.
Let’s fix that.
Philosophy
“Comment to clarify why, not just what.”
Comments should clarify intent, not restate the obvious. Good comments help others (and future you) understand decisions, edge cases, and non-obvious logic.
Purpose of Comments
Explain why something is done
Clarify non-obvious logic
Point to docs, decisions, or assumptions
Mark future work with TODO, FIXME, or HACK
Don’t comment the obvious (i++ // increment i)
Don’t write a novel inline
Don’t leave outdated comments lying around
Comment Types
1. Block Comments
Use these at the top of files or major sections to explain what the code is for.
# setup.sh
# Initializes Fathom-OS environment.
# Must be run inside a clean chroot or container.
2. Inline Comments
Use short inline notes to explain edge cases or weird behavior.
if user_id not in cache:
# Avoid stale user data on cold boot
fetch_user_profile(user_id)
3. TODO / FIXME / HACK Tags
These flag work to be done, problems to fix, or hacks to revisit.
# TODO: Refactor to systemd-native start/stop
# FIXME: Breaks if /etc/resolv.conf is missing
# HACK: Hardcoded delay, remove after upstream fix
Best Practices
- Use consistent style:
#for shell/python,//or/* */for C/Java - Keep it brief and on-point
- If it’s more than 3 lines, link to a doc
- Clean up old TODOs and remove lies
- Make your code readable enough to need fewer comments
File Headers for Scripts
When creating standalone scripts, like Bash, Python, or JavaScript files, you should include a header comment at the top of each file. This isn’t just for professionalism, it helps future maintainers (or your future self) quickly understand what the file does, who wrote it, and when it was last modified.
Use the appropriate comment syntax for the language you’re writing in.
Example for JavaScript
Similar header blocks should be used in Bash, Python, or whatever language you’re writing in, just change the comment style to match.
* Example Project - Main JavaScript
* A secure, privacy-focused password generator
* Author: The Captain Dumbass®
* Version: 1.0.0
* Last updated: 2025-06-13
Summary
Good comments:
- Are brief, relevant, and accurate
- Help others make safe, informed changes
- Make you look like someone who knows what they’re doing
Final Thoughts
Comment like someone else will read your code. Because they will.
Want more developer sanity guides like this one? Check out the rest of the Development & Code section or request a topic.
