Installing Docker and setting up a beautiful web UI for managing containers
You’ve got your server running and storage configured. Now it’s time to install the magic that makes everything easy: Docker.
Docker lets you run applications in isolated containers. No more dependency hell, no more “it works on my machine” problems. Each service runs in its own container with everything it needs.
And Portainer? That’s your web-based control panel for managing all those containers without memorizing commands.
What is Docker?
Docker is a platform for running applications in containers.
Think of containers like:
Lightweight virtual machines (but way more efficient)
Self-contained packages with everything an app needs
Isolated environments that don’t interfere with each other
Example:
Want to run a photo app? Pull a container.
Need a forum? Pull a container.
Want a wiki? Pull a container.
Each runs independently, uses minimal resources, and can be updated/removed without affecting others.
Why Docker for HomeLab?
Pros
Easy deployment - One command to install complex applications
Isolation - Apps don’t conflict with each other
Portability - Move containers between servers easily
Updates - Pull new image, restart container, done
Rollback - Something breaks? Revert to old version instantly
Resource efficient - Much lighter than VMs
Huge ecosystem - Thousands of pre-built images available
Cons
Learning curve - New concepts to understand
Networking complexity - Can be confusing at first
Storage management - Need to understand volumes
Perfect For
Web applications
Databases
Media servers
Monitoring tools
Pretty much everything we’re building in this series
What is Portainer?
Portainer is a web-based GUI for managing Docker.
Instead of typing commands like:
docker run -d --name myapp -p 8080:80 -v /data:/app/data myapp:latest
You click buttons in a web interface. Much easier for beginners (and faster for experts).
Features:
Visual container management
Template library for common apps
Stack deployment (docker-compose via web UI)
Resource monitoring
Log viewing
Network management
Volume management
And it’s completely free (Community Edition).
Installing Docker
Step 1: Update System
# Update package lists and upgrade
sudo apt update && sudo apt upgrade -y
Step 2: Remove Old Docker Packages
If you have any old Docker installations, remove them:
# Remove conflicting packages
for pkg in docker.io docker-doc docker-compose docker-compose-v2 podman-docker containerd runc; do
sudo apt-get remove $pkg
done
This ensures a clean installation.
Step 3: Install Docker’s Official Repository
Add Docker’s GPG key:
sudo apt-get update
sudo apt-get install ca-certificates curl -y
sudo install -m 0755 -d /etc/apt/keyrings
sudo curl -fsSL https://download.docker.com/linux/ubuntu/gpg -o /etc/apt/keyrings/docker.asc
sudo chmod a+r /etc/apt/keyrings/docker.asc
Add Docker repository:
echo \
"deb [arch=$(dpkg --print-architecture) signed-by=/etc/apt/keyrings/docker.asc] https://download.docker.com/linux/ubuntu \
$(. /etc/os-release && echo "$VERSION_CODENAME") stable" | \
sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
Update package index:
sudo apt-get update
Step 4: Install Docker
Install Docker Engine and tools:
sudo apt-get install docker-ce docker-ce-cli containerd.io docker-buildx-plugin docker-compose-plugin -y
This installs:
docker-ce- Docker Engine -
docker-ce-cli- Docker command-line tools -
containerd.io- Container runtime -
docker-buildx-plugin- Build tool -
docker-compose-plugin- Docker Compose (for multi-container apps)
Step 5: Verify Docker Installation
# Check Docker version
docker --version
# Test Docker with hello-world
sudo docker run hello-world
You should see a “Hello from Docker!” message. If so, Docker is working!
Step 6: Add Your User to Docker Group
This lets you run Docker without sudo:
# Add your user to docker group (replace 'admin' with your username)
sudo usermod -aG docker admin
# Log out and back in for changes to take effect
# Or run this to apply immediately:
newgrp docker
# Test without sudo
Important: Log out and back in (or reboot) for group changes to fully take effect.
Step 7: Enable Docker to Start on Boot
sudo systemctl enable docker.service
sudo systemctl enable containerd.service
Now Docker will start automatically when your server boots.
Step 8: Verify Docker Compose
Docker Compose is included as a plugin:
docker compose version
You should see something like Docker Compose version v2.x.x.
Installing Portainer
Now let’s install Portainer to manage Docker via web UI.
Step 1: Create Portainer Data Directory
Create directory on your RAID array:
# Create directory for Portainer data
sudo mkdir -p /mnt/storage/docker/portainer_data
# Set ownership (replace 'admin' with your username)
sudo chown -R admin:admin /mnt/storage/docker
Step 2: Create Portainer Network
# Create a Docker network for Portainer
docker network create portainer-network
This network will be used by Portainer and other services.
Step 3: Deploy Portainer Container
Run Portainer:
docker run -d \
--name portainer \
--restart unless-stopped \
-p 9443:9443 \
-v /var/run/docker.sock:/var/run/docker.sock \
-v /mnt/storage/docker/portainer_data:/data \
--network portainer-network \
portainer/portainer-ce:latest
What this does:
-d- Run in background (detached) -
--name portainer- Name the container -
--restart unless-stopped- Auto-restart on boot -
-p 9443:9443- Expose web UI on port 9443 -
-v /var/run/docker.sock:/var/run/docker.sock- Access to Docker -
-v /mnt/storage/docker/portainer_data:/data- Persistent data on RAID -
--network portainer-network- Connect to network -
portainer/portainer-ce:latest- Use latest Community Edition
Step 4: Configure Firewall for Portainer
On your Ubuntu server (via SSH), allow access to Portainer from your local network:
# Allow Portainer web UI from LAN
# NOTE: Replace 192.168.1.0/24 with YOUR network range
sudo ufw allow from 192.168.1.0/24 to any port 9443 proto tcp comment 'Portainer from LAN'
# Check firewall status
Step 5: Access Portainer Web UI
Open your web browser and go to:
https://192.168.1.100:9443
Replace 192.168.1.100 with your server’s IP address.
You’ll see a security warning because Portainer uses a self-signed SSL certificate. This is normal. Click “Advanced” and proceed.
Step 6: Initial Portainer Setup
First-time setup:
- Create admin account
Username:
admin(or your choice) -
Password: Choose a strong password (12+ characters)
Click “Create user”
- Connect to Docker
Select “Get Started”
Portainer will auto-detect your local Docker environment
Click on “local” to manage your Docker host
You’re in! You should see the Portainer dashboard.
Portainer Quick Tour
Dashboard
Shows containers, images, volumes, networks
Quick stats on resource usage
Containers
View all running/stopped containers
Start, stop, restart, remove containers
View logs
Access container console
Inspect container details
Images
View downloaded images
Pull new images from Docker Hub
Remove unused images
Stacks
Deploy multi-container applications
Use docker-compose files via web UI
Manage entire application stacks
Volumes
Manage persistent data storage
Create, remove, inspect volumes
Networks
Manage Docker networks
Create custom networks for container communication
Deploying Your First Container (Example)
Let’s deploy a simple test container using Portainer:
Via Portainer Web UI:
Go to Containers → Add container
Name:
nginx-test -
Image:
nginx:latest -
Port mapping:
Host:
8080 -
Container:
80
- Click Deploy the container
Access it:
http://192.168.1.100:8080
You should see the nginx welcome page!
Remove it when done:
Go to Containers
Select
nginx-test -
Click Remove
Docker Compose with Portainer
Docker Compose lets you define multi-container applications in a YAML file.
Example: Create a stack in Portainer
Go to Stacks → Add stack
Name:
test-stack -
Web editor: Paste this example:
version: '3.8'
services:
web:
image: nginx:latest
ports:
- "8080:80"
restart: unless-stopped
- Click Deploy the stack
That’s it! The container is running. Much easier than command-line.
Monitoring with Portainer
View container logs:
Go to Containers
Click on container name
Click Logs
See real-time output
View resource usage:
Go to Containers
Click Stats
See CPU, memory, network usage
Access container console:
Go to Containers
Click Console
Select
/bin/bashor/bin/sh -
Click Connect
You’re inside the container!
Best Practices
Container Data Storage
Always use volumes for persistent data
Store volumes on RAID array (
/mnt/storage/docker/) -
Never store important data inside containers (it’s lost when container is removed)
Updates
Regularly update container images
Test updates before deploying to production
Keep Portainer itself updated
Security
Use strong passwords for Portainer
Only allow Portainer access from LAN (not internet)
Regularly review running containers
Remove unused images and containers
Backups
Backup
/mnt/storage/docker/directory -
Export Portainer stacks as YAML files
Document your container configurations
Docker runs applications in isolated containers
Portainer provides a web UI for managing Docker
Installation: Add Docker repo, install Docker, deploy Portainer container
Access:
https://your-server-ip:9443 -
Benefits: Easy deployment, isolation, portability, updates
Next: We’ll set up Nginx Proxy Manager for reverse proxy and SSL in Part 5
What’s the first service you’re planning to run in Docker?
Have you used Docker before, or is this your first time?
Any questions about containers or Portainer?
