Pull Requests Explained Simply
How to review, discuss, and merge changes like a pro — without the jargon
Note:
This guide is written for solo developers working independently with Git.
If you’re working in a team or contributing to shared repositories, some practices may differ.
A follow-up guide on team workflows, conflict handling, and collaboration best practices is coming soon.
Pull requests (PRs) are how teams collaborate on code — and how solo devs keep their history clean and structured. If you’re using GitHub, learning how PRs work will instantly make you a better contributor.
What Is a Pull Request?
At its core, a pull request is a proposal:
“I made changes in a branch — here’s what I did, why I did it, and I’d like to merge this into the main project.”
It creates a safe review zone where others (or just Future You) can:
- See the changes side-by-side (diff view)
- Comment or ask questions
- Approve or suggest edits
- Automatically check for merge issues
When Should You Make a Pull Request?
Any time you’re done with a feature, bug fix, or experiment in a branch, make a PR.
Good moments to open one:
- You added a new feature and tested it locally
- You fixed a bug and want someone to double-check
- You’re ready to merge changes from your dev branch into main
You don’t need to wait until it’s perfect. PRs are where feedback happens.
What Happens During a PR?
- You open the PR: Choose a source (your branch) and a destination (usually
mainordev) - Review kicks off: GitHub shows a summary of all changes. You or teammates can leave comments
- Fixes/changes: You can push more commits to the same branch — they’ll show up in the PR
- Final review: Everyone agrees it’s good to go
- Merge: Hit the button. GitHub takes care of the rest
Solo Devs: Why Bother With PRs?
You might think: “It’s just me, why add extra steps?”
Here’s why:
- Cleaner history with a clear description of each change
- A safe space to test merge conflicts
- Optional CI/CD checks (like automated tests or linting)
- Easier to revert or reference changes later
You’re creating a logbook for Future You.
Common Mistakes to Avoid
- Merging without review: If you’re on a team, don’t skip the review process
- Forgetting to update your branch: Always pull the latest main/dev before merging
- Using PRs as a backup: They aren’t a replacement for commits or pushing often
Best Practices
- Keep pull requests focused — don’t mix bug fixes with new features
- Write a clear title and summary for your PR
- Tag reviewers or assign yourself if solo
- Use draft PRs if it’s not ready yet, but you want to start feedback early
- PRs let you review, discuss, and safely merge code
- Always branch → edit → PR → review → merge
- They’re not just for teams — solo devs benefit too
Coming Up Next:
We’ll tackle Forking vs Cloning — and why most beginners use them wrong.
