Setting up reverse proxy with automatic HTTPS for all your services
You’ve got Docker and Portainer running. Now you can deploy services. But there’s a problem:
Every service runs on a different port. Want to access your photo app? http://192.168.1.100:2283. Your forum? http://192.168.1.100:8080. Your wiki? http://192.168.1.100:3000.
That’s ugly and hard to remember.
What if instead you could use:
https://photos.homelab.example.com -
https://forum.homelab.example.com -
https://wiki.homelab.example.com
Clean URLs. HTTPS encryption. One tool: Nginx Proxy Manager.
What is a Reverse Proxy?
A reverse proxy sits in front of your services and routes traffic to the right place.
Think of it like a receptionist:
You ask for “photos” → They direct you to port 2283
You ask for “forum” → They direct you to port 8080
You ask for “wiki” → They direct you to port 3000
Benefits:
Clean domain names instead of IP:port combinations
Automatic SSL certificates (HTTPS)
Single entry point for all services
Access control and authentication
Load balancing (for advanced setups)
Why Nginx Proxy Manager?
Nginx is the industry-standard reverse proxy. It’s powerful but complex to configure.
Nginx Proxy Manager (NPM) gives you a beautiful web UI to manage Nginx without editing config files.
Features
Web-based GUI - No command-line config editing
Free SSL certificates - Automatic Let’s Encrypt integration
Auto-renewal - SSL certs renew automatically
Access lists - Control who can access what
Custom locations - Advanced routing rules
Stream forwarding - TCP/UDP proxying
Dead simple - Seriously, it’s that easy
Perfect For
HomeLab services with clean URLs
Automatic HTTPS for everything
Centralizing access to multiple services
Learning reverse proxy concepts
What You’ll Need
Prerequisites
Docker installed (Part 4)
Portainer running (Part 4)
Domain name (optional but recommended)
Paid: Namecheap, Cloudflare, etc. (~$15/year)
Free: DuckDNS
Ports Required
Port 80 - HTTP traffic
Port 443 - HTTPS traffic
Port 81 - NPM admin interface
Installing Nginx Proxy Manager
We’ll deploy NPM using Portainer Stacks.
Step 1: Create Data Directory
# Create directory for NPM data
sudo mkdir -p /mnt/storage/docker/nginx-proxy-manager/data
sudo mkdir -p /mnt/storage/docker/nginx-proxy-manager/letsencrypt
# Set ownership (replace 'admin' with your username)
sudo chown -R admin:admin /mnt/storage/docker/nginx-proxy-manager
Step 2: Deploy via Portainer
Login to Portainer:
https://192.168.1.100:9443
Create new stack:
Click Stacks in left sidebar
Click + Add stack
Name:
nginx-proxy-manager -
Build method: Web editor
Paste this compose configuration:
services:
app:
image: 'jc21/nginx-proxy-manager:latest'
container_name: nginx-proxy-manager
restart: unless-stopped
ports:
- '80:80' # Public HTTP Port
- '443:443' # Public HTTPS Port
- '81:81' # Admin Web Port
environment:
TZ: "America/New_York" # Change to your timezone (see note below)
DISABLE_IPV6: 'true'
volumes:
- /mnt/storage/docker/nginx-proxy-manager/data:/data
- /mnt/storage/docker/nginx-proxy-manager/letsencrypt:/etc/letsencrypt
Note about timezone (TZ):
Find your timezone code at: List of TZ Database Timezones
Examples:
America/New_York,America/Los_Angeles,Europe/London,Asia/Tokyo -
Use the value from the “TZ identifier” column
Deploy:
Scroll down
Click Deploy the stack
Wait 1-2 minutes for deployment
Step 3: Configure Firewall
On your Ubuntu server (via SSH), allow NPM ports from your local network:
# Allow HTTP from LAN
sudo ufw allow from 192.168.1.0/24 to any port 80 proto tcp comment 'HTTP from LAN'
# Allow HTTPS from LAN
sudo ufw allow from 192.168.1.0/24 to any port 443 proto tcp comment 'HTTPS from LAN'
# Allow NPM admin from LAN
sudo ufw allow from 192.168.1.0/24 to any port 81 proto tcp comment 'NPM Admin from LAN'
# Check firewall status
Note: Replace 192.168.1.0/24 with your network range.
Step 4: Access NPM Admin Interface
Open your browser:
http://192.168.1.100:81
Default login credentials:
Email:
admin@example.com -
Password:
changeme
** IMPORTANT:** You’ll be forced to change these on first login. Choose a strong password!
Step 5: Initial Setup
On first login:
- Change email and password
Enter your email address
Choose a strong password (12+ characters)
Click Save
Need a strong password?
Recommended: Use a password manager (Bitwarden, 1Password, Proton Pass, KeePassXC)
Generate via command line:
# Generate a 20-character random password
openssl rand -base64 20
- You’re in! You should see the NPM dashboard.
Setting Up Your Domain
You have two options for domain names:
Option 1: Paid Domain (Recommended)
Register a domain:
Namecheap (~$15/year)
Cloudflare (~$10/year)
Porkbun (~$10/year)
Example: homelab.example.com
For this guide, we’ll use: homelab.example.com as a placeholder. Replace with your actual domain.
Option 2: Free DuckDNS
Sign up at DuckDNS
Login with Google/GitHub
Create a subdomain:
yourhomelab.duckdns.org -
Point it to your home IP address
Free forever!
DNS Configuration
You need to point your domain to your server. You have two approaches:
Approach 1: Local DNS Only (What I Use)
Best for: Services only accessed from home network
Setup:
Configure your router or DNS server (like Pi-hole, OPNsense) to resolve your domain locally
Create a wildcard DNS entry:
*.homelab.example.com→192.168.1.100 -
Domain doesn’t resolve publicly (more secure)
Pros:
More secure (not exposed to internet)
Works without port forwarding
No dynamic DNS needed
Cons:
Only works on your local network
Can’t access services remotely
Approach 2: Public DNS + Port Forwarding
Best for: Accessing services from anywhere
Setup:
Point domain to your public IP at your registrar
Configure port forwarding on router:
Forward port 80 → 192.168.1.100:80
Forward port 443 → 192.168.1.100:443
- Use dynamic DNS if you don’t have static IP
Pros:
Access services from anywhere
Works outside your network
Cons:
Exposes services to internet (security risk)
Requires port forwarding
Need dynamic DNS for changing IPs
** Important Considerations:**
ISP Terms of Service: Some ISPs prohibit running servers on residential connections. Check your ISP’s acceptable use policy.
ISP Equipment: If you’re renting a modem/router from your ISP, it may have limited or disabled port forwarding capabilities. Consider using your own router.
Port Blocking: Some ISPs block common ports (80, 443, 25) on residential connections. You may need to use alternative ports.
Dynamic IP: Most residential connections have dynamic IPs that change periodically. Use a dynamic DNS service (DuckDNS, No-IP, etc.) to keep your domain updated.
** Security Warning:** Only expose services to the internet if you understand the security implications. Use strong passwords, keep services updated, and consider VPN access instead.
Getting SSL Certificates
NPM makes SSL certificates incredibly easy with Let’s Encrypt.
Method 1: HTTP Challenge (Easiest)
Requirements:
Domain must be publicly accessible
Ports 80 and 443 forwarded to your server
Steps in NPM:
Go to SSL Certificates
Click Add SSL Certificate
Select Let’s Encrypt
Domain Names: Enter your domain (e.g.,
photos.homelab.example.com) -
Email: Your email for renewal notifications
Use a DNS Challenge: Leave unchecked
Agree to Terms: Check the box
Click Save
NPM will:
Request certificate from Let’s Encrypt
Verify domain ownership via HTTP
Install certificate automatically
Auto-renew before expiration
Method 2: DNS Challenge (Advanced)
Requirements:
API access to your DNS provider
Works even without public access
Supported providers:
Cloudflare
Namecheap
DuckDNS
Many others
Steps in NPM:
Use a DNS Challenge: Check this box
DNS Provider: Select your provider
Credentials: Enter API credentials
Propagation Seconds: 120 (2 minutes)
Click Save
This is what I use - works with local-only DNS.
Creating Your First Proxy Host
Let’s proxy Portainer so you can access it via a clean URL.
Step 1: Add Proxy Host
In NPM:
Go to Hosts → Proxy Hosts
Click Add Proxy Host
Step 2: Configure Details Tab
Domain Names:
- Enter:
portainer.homelab.example.com
Scheme:
- Select:
https(Portainer uses HTTPS)
Forward Hostname / IP:
Enter:
192.168.1.100(your server IP) -
Or:
portainer(if using Docker network)
Forward Port:
- Enter:
9443(Portainer’s port)
Options:
Cache Assets
Block Common Exploits
Websockets Support (important for Portainer)
Step 3: Configure SSL Tab
SSL Certificate:
Select your Let’s Encrypt certificate
Or click Request a new SSL Certificate
Options:
Force SSL
HTTP/2 Support
HSTS Enabled (leave unchecked for now)
Step 4: Save and Test
Click: Save
Test it:
https://portainer.homelab.example.com
You should see Portainer! No more remembering ports.
Adding More Services
Repeat the process for each service:
Example: NPM itself
Domain:
npm.homelab.example.com -
Forward to:
192.168.1.100:81 -
SSL: Use your certificate
Example: Future services
Photos:
photos.homelab.example.com→ port 2283 -
Forum:
forum.homelab.example.com→ port 8080 -
Wiki:
wiki.homelab.example.com→ port 3000
Security Best Practices
Docker Network Setup (Important!)
For NPM to proxy to other Docker containers using container names, they must be on the same network.
Connect NPM to Portainer’s network:
On your Ubuntu server (via SSH):
# Connect NPM to portainer-network
docker network connect portainer-network nginx-proxy-manager
# Verify connection
docker inspect nginx-proxy-manager --format='{{range $net,$v := .NetworkSettings.Networks}}{{$net}} {{end}}'
# Should show: nginx-proxy-manager_default portainer-network
Now you can proxy to containers by name:
Use
portainerinstead of192.168.1.100:9443 -
Use
nginx-proxy-managerfor NPM itself
For future services:
Connect them to
portainer-networkin their docker-compose files -
Then use container names (e.g.,
immich_server,wikijs,discourse) -
This is cleaner than using IP addresses and works even if IPs change
Access Lists
Restrict access to sensitive services:
Go to Access Lists
Click Add Access List
Name:
LAN Only -
Authorization:
Satisfy Any: Off
Pass Auth: Off
- Access:
Allow:
192.168.1.0/24 -
Deny:
all
- Click Save
Apply to proxy host:
Edit proxy host
Access List: Select
LAN Only -
Save
Note: Access lists work best when using IP addresses in the “Forward Hostname/IP” field. If using container names, the access list restricts who can access the domain, not the backend container.
Strong Passwords
Use unique, strong passwords for NPM admin
Enable 2FA if available (future feature)
Don’t use default credentials
Keep Updated
Regularly update NPM container
Check for security advisories
Monitor access logs
Nginx Proxy Manager provides reverse proxy with web UI
Clean URLs instead of IP:port combinations
Free SSL certificates via Let’s Encrypt
Installation: Deploy via Portainer stack
Configuration: Add proxy hosts for each service
DNS: Local DNS or public with port forwarding
Next: We’ll install Immich for photo management in Part 6
Are you using local-only DNS or exposing services publicly?
What domain registrar do you prefer?
Any questions about reverse proxy or SSL certificates?
